Hi
1. I have a issue with displaying assemblies (using Creo Parametric 8.0.7.0). Sometimes I have different family table instance component displayed on assembly view than is defined in family table and displayed in assembly tree. What might be the reason?
2. I have also an issue with drawings. Sometimes on drawing view (with assembly) I have missing component but when I opening assembly that is presented on the drawing it is complete. What might be the reason?
@GG_6495306 wrote:
Hi
pack problematic data into zip file and upload it.
Hi Martin
Unfortunately I cannot share the files outside my organization. Moreover it is not something that is easy to reproduce with the same data on different computers. Sometimes it happens and sometimes not but thinks like regeneration or opening wrong component in a separate window does not always correct what is displayed.
Regards
Grzegorz
@GG_6495306 wrote:
Hi Martin
Regards
Grzegorz
Suggestion: If problem occurs then close Creo session, start new one and open assembly again.
If you are able to reproduce the problem then you have to check the whole assembly.
Suggestion: If problem occurs then close Creo session, start new one and open drawing again.
If you are able to reproduce the problem then create new drawing and add view into it. This enable you to find out whether the problem is related to drawing -OR- to assembly.
Note related to family tables: Every instance name must be unique. This applies to family tables in all models.
Hi Martin
Seems that assemblies and parts were correct.
We have applied config setting: SAVE_INSTANCE_ACCELERATOR none
With this setting Creo is working correctly so far. Since issue was not easy to reproduce we need 1 month to be able to say that this solved the problem.
Regards
Grzegorz
