Hi all, its been a while! Does anyone know if its possible to change the cross height of a Z-radius dimension? The default height appears to be 5mm & is annoyingly large. I have been searching for a possible config option but have drawn a blank thus far.
John
The cross termination symbol of the Z-radius dimension appears with a size of 5 mm by 5 mm or an equivalent value in English units. The line style of the cross symbol is solid font with the color similar to that of the dimension text.
* You cannot change the size of the cross termination symbol of the Z-radius dimension.
This is documented in the help files:
I think the fastest way to get answer is to open Case at PTC Support.
Thank you! That is a shame. Like i said, it is annoyingly large & interferes with dimension text on occasion.
John
