I just want to know about Zoom to selected func. how they are calualting values of PanX, PanY and PanZoom. Please some one give me a quick answer. Or Any other idea how to get PanX and PanY position.
it's urgent. Attached snapshot of the option.
Thank you in advance.
The Zoom to Selected function will center the part/subassembly in the screen and zoom to the model envelope/size, filling ~75%(?) of the window. I don't know of any way to get the "PanX, PanY and PanZoom" vaules or exactly how they are calculated.
The only issue with it is that the model envelope/size takes into account all datums, curves, surfaces, and solids. This may cause the zoom to be far out and to the side of the actual solid of the part. A datum far from the solid body will cause this issue. There are Ideas in the Idea board to ignore the datums for calculating zoom. Here is a zoom to selected of small part with a CSYS in space:
