Appearance.dmt file with a ton of HTML colors included.
where do I put this in the creo 3 files so that it opens automatically. I had it working in creo 2 but its not working in 3. thanks.
It should work if you unzip it into your "start in" directory.
Alternately, you can set the config option "pro_colormap_path" to point to a directory containing the "appearance.dmt" file.
-Doug
I'm not sure about Creo 3. Does it not have a 'graphic-library' folder the same way Creo 2 does?
Anyway, the config option Doug mentions should work.
that's where it is. it works like creo2
the pro_colormap_path wasn't working.
thanks all.
