after installation of creo 11 student version the screen became black and no entities are highlited when drawn. My graphic card is RTX3050. windows 11
Hi @GV_13707164 ,
This is likely due to the change in the default value for config.pro option enable_fsaa. Setting this to a different value in session and causing a screen repaint should resolve the black screen. You may need to try a few different values for the option to find which works for your configuration.
Refer to CS348177 for more information.
Hi @GV_13707164 ,
Hi @GV_13707164,
Anurag
