call family table instance with pro/programs
cyılmaz
8-Gravel
hello everyone,
i want to replace  *.prt with pro/programm from family table
but this *.prt is generic it have a family table
how can i replace?
Best Regards,
Cömert YILMAZ
If you know the name of the instance you want to place, it's easy...
Put this in your RELATIONS (or use an INPUT PARAMETER)
MY_INSTANCE = "510FB0158_1"
Then open your PRO/PROGRAM and look where the current part is being placed.
ADD PART 510FB0_158_159_160
END ADD
Now replace "510FB0_158_159_160" with "(MY_INSTANCE)"
ADD PART (MY_INSTANCE)
END ADD
Now change the value of MY_INSTANCE 🙂
When this succeeds, you could also look into the "lookup_inst" function...but that's a whole different ballgame
7 REPLIES 7
See Creo Parametric Help Center Example: A Parametric Design for a Blender Cover
END ADD
END ADD
thank you so much  for help
No problem.
If you want to know more about the lookup_inst then just give a shout 🙂
Hi TeunHam,
i don't know lookup_ins or what does it .
but i have i problem .
i have two parts and there are generic part. (510FB0161.ASM and 510FB0166_167_168.ASM)
if my chose 510FB0161_1 i want to the suppress 510FB0166_167_168.ASM
or
if my chose 510FB0166_1 i want to the suppress 510FB0161.ASM
you can see program;
VERSION 3.0
REVNUM 474
LISTING FOR ASSEMBLY S1_FAN_OMEGA
INPUT
S1_OMEGA_TIPI NUMBER
"OMEGA TİPİNİ SEÇİNİZ. ( 1=SINGLE , 2=DUAL )"
S1_HAVA_AKIS_YONU NUMBER
"HAVA AKIŞ YÖNÜ SEÇİNİZ. ( 1=SAĞ , 2=SOL )"
S1_TEK_PARCA_FB_SINGLE STRING
"FB KODUNU GİRİNİZ.(510FB0161_...)"
S1_PARCALI_FB_SINGLE STRING
"FB KODUNU GİRİNİZ.(510FB0166_.,510FB0167_.,510FB0168_.)"
S1_TEK_PARCA_FB_DUAL STRING
"FB KODUNU GİRİNİZ.(510FB0152_...)"
S1_IKI_PARCALI_FB_DUAL STRING
"FB KODUNU GİRİNİZ.(510FB0157_...)"
S1_PARCALI_FB_DUAL STRING
"FB KODUNU GİRİNİZ.(510FB0163_.,510FB0164_.,510FB0165_.)"
END INPUT
RELATIONS
WEIGHT=PRO_MP_MASS
END RELATIONS
ADD FEATURE (initial number 1)
INTERNAL FEATURE ID  1
DATUM PLANE
  NO.     ELEMENT NAME    INFO
   1      Feature Name    Defined
   2      Constraints     Defined
   2.1    Constraint #1   Defined
   2.1.1  Constr Type     X Axis
   3      Flip Datum Dir  Defined
   4      Fit             Defined
   4.1    Fit Type        Default
NAME = ASM_RIGHT
    FEATURE IS IN LAYER(S) :
      01__ASM_ALL_DTM_PLN - OPERATION = SHOWN
      01__ASM_DEF_DTM_PLN - OPERATION = SHOWN
END ADD
ADD FEATURE (initial number 2)
INTERNAL FEATURE ID  3
DATUM PLANE
   2.1.1  Constr Type     Y Axis
   4      Fit             Defined
NAME = ASM_TOP
END ADD
ADD FEATURE (initial number 3)
INTERNAL FEATURE ID  5
DATUM PLANE
   2.1.1  Constr Type     Z Axis
   4      Fit             Defined
NAME = ASM_FRONT
END ADD
ADD FEATURE (initial number 4)
INTERNAL FEATURE ID  7
TYPE = COORDINATE SYSTEM
NAME = ASM_DEF_CSYS
      05__ASM_ALL_DTM_CSYS - OPERATION = SHOWN
      05__ASM_DEF_DTM_CSYS - OPERATION = SHOWN
END ADD
IF S1_OMEGA_TIPI==2
     ADD SUBASSEMBLY S1_OMEGA_DUAL
     INTERNAL COMPONENT ID 40
     END ADD
END IF
IF S1_OMEGA_TIPI==1
     ADD SUBASSEMBLY S1_OMEGA_SINGLE
     INTERNAL COMPONENT ID 49
     END ADD
END IF
IF S1_OMEGA_TIPI==1
     IF S1_HAVA_AKIS_YONU==2
         ADD SUBASSEMBLY (S1_TEK_PARCA_FB_SINGLE)
         INTERNAL COMPONENT ID 60
         PARENTS = 49(#5)
         END ADD
        ADD SUBASSEMBLY (S1_PARCALI_FB_SINGLE)
         INTERNAL COMPONENT ID 63
         PARENTS = 49(#5)
         END ADD
     END IF
     IF S1_HAVA_AKIS_YONU==1
         INTERNAL COMPONENT ID 68
         PARENTS = 49(#5)
         END ADD
         INTERNAL COMPONENT ID 73
         PARENTS = 49(#5)
         END ADD
     END IF
END IF
IF S1_OMEGA_TIPI==2
         ADD SUBASSEMBLY (S1_TEK_PARCA_FB_DUAL)
         INTERNAL COMPONENT ID 76
         PARENTS = 40(*)
         END ADD
         ADD SUBASSEMBLY (S1_IKI_PARCALI_FB_DUAL)
         INTERNAL COMPONENT ID 83
         PARENTS = 40(*)
         END ADD
         ADD SUBASSEMBLY (S1_PARCALI_FB_DUAL)
         INTERNAL COMPONENT ID 88
         PARENTS = 40(*)
         END ADD
     END IF
         INTERNAL COMPONENT ID 93
         PARENTS = 40(*)
         END ADD
         INTERNAL COMPONENT ID 98
         PARENTS = 40(*)
         END ADD
         INTERNAL COMPONENT ID 103
         PARENTS = 40(*)
         END ADD
     END IF
END IF
MASSPROP
END MASSPROP
CAD_user
(To:cyılmaz)
For doing this, do I need aax extension?
In my creo I don't have the aax extension, but I'm able to open and edit Pro program.
I know it's out of context but I still haven't figure out, what aax unlocks.
