I have tried everything; there no way to select the drawing xhatch and change spacing or angles. I have looked up all the online answers and my GUI doesn't not have a modify xhatch.
Please help
Hi Michael,
When you are in the Layout tab of the drawing, you should be able to hover over and highlight the xhatch. Then after selecting it, Properties should be available in the RMB menu, which should open the MOD XHATCH menu manager.
Please upload your files to the thread, so we can take a look at the issue.
Amit
Hi Michael,
Amit
Thanks, I was not in Layout mode I was in Annotate mode; I did find it in legacy migration mode; but after looking around finally found it.
thank
Hi Michael,
Glad that worked. Would you mind marking it as the Correct Answer, so any other user, looking for a similar solution, can find it easily.
Amit
