changing dimensioning scheme in the sketch section of an extrude - how??
jferguson4
Can someone point me to a good explanation or youtube on how to change dimension schemes in Creo 9?
For example, if it want to locate a crank-pin on the face of a cylindrical model, I would want the dimensions to by the diameter of the pin and the radial distance from the axis of the cylinder, not the dimensions to two planes.  It looks like there is some simple way to step the dimension set through the choices which will work.
I is there a group of training videos here that I can access to learn some of these improvements? If so, where are they?
Yes, I know this is a simple question, but.....
youtube.com ... creo dimension diameter
returns the link ... https://www.youtube.com/watch?v=Zig2lhj24WI
Hope it helps ...
Martin Hanák
3 REPLIES 3
Hope it helps ...
Martin Hanák
Thanks much Martin.  I had watched it but had failed to grasp the whole thing.  I've been doing simple models to get quicker with rescehemihng the dimensions and now seem to be succeeding.
jferguson4
(To:jferguson4)
More good news I've spent time practicing on non-revenue parts and think I finally have it under control.  thanks again for the reference.
