hello
i have a problem when i create a drawing creo create colors of lines white and some cases green
is a parameter for control this?
i whant for example color red when i export in dxf it is posible?
tks
Bogden,
The part you are using for drawing creation is a Sheetmetal part and that is the reason for Green and White edge.
If you would like to change the color of edge from green to red, change sheetmetal color from File > Options > System Colors > Graphics and change the color for Sheetmetal
next question is how export in layer 0 in autocad for example
When exporting drawing to DXF,Under Export Settings you can set the layer as 0 under layers and you can map color as well for Sheetmetal.
Bodgen,
Did the earlier reply help you?
