config.pro option to turn off display of tolerance tag...
pdkoren
7-Bedrock
In WF3 (though probably same for other version) what is the config.pro option to turn OFF the display of the tolerance scheme in the model window (shown in the attached picture) in the lower right corner. This is the 4 lines of text showing the setting of the default tolerances (x.x +-0.1, x.xx+-0.01...) that I can manual turn off by TOOLS- ENVIRONMENT and then unchecking the "±.01 Dimension Tolerances" box...
thanks...
pdkoren
7-Bedrock
(To:pdkoren)
tol_display no
Thanks Charlie!
The tag on the drawings it turned off by display_dwg_tol_tags
The tol_display no will not allow dimensions on the drawing to have tolerances and the tolerance box under properties will be grayed out.
