I have a problem with cotation of holes made by a group pattern around axis.
I would need to use linear cotation of those holes but after the pattern is done it will switch to radial cotation.
There is a switch in <detail>.dtl that creates the radial axis pattern.
radial_pattern_axis_circle *NO/YES
I am not sure this is a live switch. You have to play with that. It lets you create radial patterns when a hole is patterned axially. By default this is NO, so it is set in a config file somewhere.
Tomas,
I think that nobody understand you because you are using the word cotation (tipuji, že česky je to kótování). Maybe dimensioning scheme is the right word
Also dimensions are missing on you pictures. Therefore nobody knows, what do you want to get.
Martin Hanak
it seems somebody understood very well.
Thank you very much....
