create a relation with fonction in a part
sclamens
How to create a relation in a part in order to controle a fonction? I would like with a relation inhibit or not one fonction depending on a parameter Y/N
5 REPLIES 5
unfortunatelly I do not understand your question.
You can use translate.google.com web page to get english translation 🙂
Martin Hanák
sclamens
(To:MartinHanak)
How to create a formula that drives a function to enable or disable this function?
again ... unfortunatelly I do not understand your question.
Please provide some example.
Martin Hanák
I have a feeling that you are talking about FEATURES (not FUNCTIONS)
Anyway, in the relations of a part or assembly, you can make use of these internal FUNCTIONS:
http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/fundamentals/fundamentals/fund_seven_sub/About_Functions_Used_in_Relations.html
Or, you can create your own function with a C Program:
http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/fundamentals%2Ffundamentals%2Ffund_seven_sub%2FAbout_an_Interactive_C_Program.html%23
If you want to drive FEATURES (turning them ON of OFF by suppressing them) in your model tree, then you must write a simple IF...THEN statement in PRO/Program:
http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/fundamentals%2Fprogram%2FAbout_Pro_PROGRAM.html%23
http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/fundamentals%2Fprogram%2FExample_A_Parametric_Design_for_a_Blender_Cover.html%23
HTH1
@sclamens, did you get a correct answer?
