After creating sheet metal parts on Creo 11.0.1, the wall thickness of sheet metal is set to read-only, so it can't be modified. I've already reported this bug to our distributor, but they said there is no solution right now, or return to old version. Is there any solution please share.
please read following documents
https://www.ptc.com/en/support/article/CS416999
https://www.ptc.com/en/support/article/CS420358
I don't use the sheetmetal features much, but a "trick" I might try is to use a relation to set the wall thickness. Sometimes there are parameters that are not editable directly but they can be changed with a relation.
In case you are completely unfamiliar with relations, you'd need to select the dimension that specifies your thickness, make a note of its name (something like "d10" or whatever). Then use Tools->Relations to enter something like d10=<new thickness>.
This is a huge guess on my part, I'm not confident you'll be able to skirt the issue with this, but it's worth a try.
Great thank!
Your 2nd link helped to resolve the issue. And I did follow the 1st article by removing custom template, but it didn't work.
Thank you again.
