creo parametric 3d and zwcad/autocad 2d
bcat
9-Granite
hello
I want a sugestion for productivity designing
In actual time i use zwcad for sketch ,creo parametric for 3d , and again zwcad for 2d details drawing
is a good working manner ?
from experience of many users what do you work
a problem is to translate layers in creo to autocad or reverse
how resolve this problem ?
i want to use same layers in both software
one response i know 🙂 use one software but in assambly i have lot of variants and creo dont now what i want
Tks
MartinHanak
(To:bcat)
it is not possible to configure Creo to transfer layers from Creo objects to 2D DWG/DXF in a simple way. If you own full AutoCAD, you can develop LISP script to modify 2D DWG/DXF file exported from Creo. Note: Creo uses dxf_export.pro file to configure export od Creo drawing to 2D DWG/DXF.
Martin Hanák
