creo part file fatal error
rahulsardar1
6-Contributor
I am using Creo Parametric 7.0 7.0.3.0
Customer reports fatal error while adding critical radius on solid or surface model.
Attaching snapshot for reference along with traceback.log file.
Here are the errors that I faced
fatal error
1 ACCEPTED SOLUTION
Hello Mr. Sardar,
I opened this technical support case C15964172  from community Conversation #25797416 . Please send me the model along with the sequence to investigate and the details of the error.
Please also accept the case as solution within Conversation #25797416 .
Sincerely,
Harald Hiller
4 REPLIES 4
I recommend opening a case with PTC Tech Support. It's unlikely folks on the Community will be able to parse the traceback file (myself included).
Also, there's nothing attached in your post.
Luke
Hello Mr. Sardar,
Sincerely,
Harald Hiller
rahulsardar1
6-Contributor
(To:hhiller)
accepting  the case as solution within Conversation #25797416 .
HI
can you please suggest me .
I am unable to delete outdated feature in cabling.
