I am in a process of modifying somebody's drawing and one of the sections is cross hatched with a style (like double line) that I would like to modify to another style (material)
I went to the corresponding part and assy and made sure that x-hatching there is correct.
So what can I do to modify x-hatching style (not spacing or angle) in my drawing?
Thank you
I figure it out: you retrieve the style you want from the list in MOD XHATCH
Best
Hello Eugene Goldenberg,
Could you please check option "ADD LINE" when double clicking on hatching in the drawing. It will helpfull for your problem.
Thanks & Regards,
Naveen Kumar Gongu
Naveen, thanks
Yes it added a line.
But I would like to change the STYLE of x-hatching by redefining it somehow.
Best
