cutting/capping surfaces...
PAULKORENKIEWIC
In the results display of a Mechanica analysis, I insert a capping
surface to see "inside" a hollow part. In order to show the maximum
stress I need to select "OK" on the cutting/capping surface pop-up
definition window. Once I do this, I can then use INFO-VIEW MAX to show
the stress. NOW, I would like to CHANGE the capping surface to look at
the other side, BUT???? The only way I have found to do so is to click
on EDIT THE SELECTED RESULT WINDOW then select the OK AND SHOW button
which just turns off the capping surface. Then I have to redo the
capping surface all over again... IS there an "edit" somewhere I'm
missing??? Is there any shortcuts around this?
Thanks...
Paul Korenkiewicz
FEV, Inc.
4554 Glenmeade
Auburn Hills, MI., 48326
vpotturu
(To:PAULKORENKIEWIC)
We can edit capping surface using 'Edit->Capping Surf" menu.
Vasanth
This is what I was missing... thanks all who replied!
