datum point on curve start point
ptc-2860737
Hi
When placing a datum point on a sketched curve with multiple line segments
the start point seems to be arbitrary. Is there any way to select one of
the other vertices in the curve as the start point?
Doug Barton
Senior Mechanical Designer
Parker Hannifin Electronic Controls
Electronic Controls Division
1305 Clarence Avenue
Winnipeg, MB R3T 1T4 Canada
direct 204 453 3339 x309
fax 204 452 7156
www.parker.com/ecd
PLEASE NOTE: The preceding information may be confidential or
privileged. It only should be used or disseminated for the purpose
of conducting business with Parker. If you are not an intended
recipient, please notify the sender by replying to this message and
then delete the information from your system. Thank you for your
cooperation.
0 REPLIES 0
