I am using Creo Parametric Release 10.0 and Datecode10.0.5.0
HI, the question came up, if there are any downsides, when i define my assembly-relations with driven-dimensions (eg. 3D-Annotations) instead of the dimensions of the component (driving dimensions).
in my opinion, it is not possible to give a clear answer. It always depends on what the given relations are driving and how complicated they are.
Hi @FZimmermann
I would echo with Martin as there is no direct yes or no answer. If there is any specific use case, share that here for clerification.
Thanks.
