Okay, so in summary, between Bob and Wayne there was an "easy" fix.
For completeness, here is everything (I think) I changed to get from decimal degrees to degrees-minutes-seconds...
In the CONFIG.PRO I added ANG_UNITS ANG_SEC.
In the drawing setup file, I set the following:
draw_ang_unit_trail_zeros no
In the drawing, I edited the properties of the dimension and set it to DEGREES,MIN,SEC
I think that is all I did to make the switch for this draiwng.
Thanks again for the quick responses,
Steve
