drawing units
AK_10785316
2-Explorer
drawing units
how do I set the units of a drawing to display mm regardless of the units set in a part model.
i.e. Part model is in inch units but I want the drawing to display in mm.
7 REPLIES 7
tbraxton
22-Sapphire I
(To:AK_10785316)
Check out these threads on the subject (found using search term dual dimension):
Posts - PTC Community
Involute Development, LLC
Consulting Engineers
BenLoosli
(To:AK_10785316)
Create your drawing template in the units that you want for your drawing dimensions.
the drawing template has the units set to mm and the model has the units has the units set to inch.
the dimensions in the drawing show in inch even though the drawing template is set to mm.
tbraxton
22-Sapphire I
(To:AK_10785316)
There are, depending of what you want, different ways to manage units in a drawing.
A- For new drawings:
1) If you don’t use templates:
  You should complete two files:
  In CONFIG.PRO:
  Set DRAWING_SETUP_FILE to the location of PRODETAIL.DTL
        (eg: drawing_setup_file c:\proeconfig\prodetail.dtl)
  Then complete PRODETAIL.DTL with:
  DRAWING_UNITS   mm
2) If you use Templates:
  Edit each Template, go to FILE/PREPARE/DRAWING PROPERTIES, click CHANGE on line "Detail options" and set the line DRAWING UNITS to: "DRAWING_UNITS mm" then save your Template.
B- For existing drawings:
  Do the same as for Template files, for each ones.
(Creo reads PRODETAIL.DTL once when creating a drawing, then copy all options in the drawing. Hence none of PRODETAIL modification will affect already created drawings)
thank you all for the responses.
I have a drawing template set to mm and a .dtl file set to mm but it still shows the inch dimension of the model.
The .prt is set to inch.
If I change the .prt to mm then the drawing shows the dimension mm.
If I change the .prt back to inch the drawing updates to show the inch dimension.
the drawing is not converting the model's inch dimension to mm.
Hi AK,
I'm having this same issue. It seems the only thing that DRAWING_UNITS does is set the units for the size of the annotations in the drawing instead of being related to the units of the dimensions. Maybe there's more to it.
Have you found a solution to your problem?
kdirth
(To:GV_SVT)
Try File>Prepare>Drawing Properties>Detail Options:
dual_secondary_units mm
dual_dimensioning secondary
