.dxf Export & import not successful in Creo Schematic.
GopiGanesh
When ever i am trying to import or Export a Block symbol its not exporting successful.
I like to create a same kind of shape with or without terminals...
Making of a block symbol is not so easy in this tool....because the drafting is not easy like pro-e.
so i used to create symbols in pro-e & i ll export as .dxf. the i ll import in Creo schematic.
some time if i want to copy the same symbol for another shape....there is no option to copy and paste .
in this case if we try to export the same symbol as .dxf. that is also not working.
Please refer the attachment to see the error. I am expecting some simple ideas to copy a symbol to reuse many times.
Thanks in advance.
1 REPLY 1
Hi Gopi,
Have you filed this bug with tech support? My guess is that an internal error is preventing the import but they'd really need a trail file to reproduce it and fix it (with the DXF that causes the problem).
FYI (using Creo Schematics 2.0) I was able to successfully export and import a DXF file so the functionality does exist - it may be a problem specific to your case.
Martin
