export drawing to a directory in PDF format in part number order
RK_14385350
2-Explorer
We use PTC CREO for our engineering system, I am being told that we cannot export drawing to a directory in PDF format in part number order. Is it possible?
I do not understand what export drawing to a directory in PDF format in part number order means. Does this mean that you need to extract name from model parameter and use it as PDF file name?
Martin Hanák
The question is not clear as to the purpose of such an activity. As my understanding goes....
  1. you have drawings with certain numbers in a serial order
  2. You wish to print them all to a folder in PDF format with one single print command to a folder
If yes, then one can Open All the Drawings in Creo View and Print multiple drawings with one single print command to PDF.
Srinivasan Iyer
