Tools>Program>Show Design>Edit> Select and copy all.
Open start part.
Tool>Program>Edit Design>Edit> Paste
Disclaimer: I haven't tried this 😉
In Reply to Chris Rees:
PTC says that there isn't a way to do this and there probably isn't but
I was wondering if anyone has thought about it.
Is there a way to export feature history into a text file so it can be
re-created again from a blank start part?
The only thing I can think of is if there was a way to make Pro/E step
through every feature and then you could save the trail file and run
that again. I don't know if there is a way to make Pro/E step through
every feature in such a way that it would record enough information in
the trail file though.
I realize there are UDFs and I could just save a copy but that's not
what I want.
Chris
This communication, including any attachments, consists of non-public
information that is intended solely for use of the individual or entity
to which it is addressed. It is a confidential communication that may
contain information that is proprietary, privileged, export-controlled
and/or exempt from disclosure under applicable U.S. and non-U.S. law.
If the reader is not the intended recipient, or agent responsible for
delivering the message to the intended recipient, please notify the
sender immediately by reply e-mail and delete the communication,
including any attachments, from your system without saving any
information or making any physical copies. Unauthorized use,
dissemination, distribution or copying of this communication, including
any attachments, is strictly prohibited.
