extrusion on the side of a round cap at a different angle.
FD_9999148
2-Explorer
I am using Creo Parametric - Release 8.0 (connected) Release 8.0 and Datecode8.0.1.0
I am trying to create an extrusion on a side of a plastic cap that is on an angle approximately half way up. It is a detailed serration that has a radius of .016 deep and a quantity of 106 around the perimeter.
StephenW
(To:FD_9999148)
Glad i could help. @FD_9999148  Please mark the solution so it might help someone else in the future.
7 REPLIES 7
StephenW
(To:FD_9999148)
You'll need to give more information or a picture or some indication of what your problem is. Error message? Pattern difficulties?
This is the surface I am having trouble extruding a serration onto. The lower part of the surface I have a serration established and now I need to add one one directly above it so it can be patterned to 106 total around the outside. I attempted to use the plane at the beginning of the angle and add a taper to it and no luck. Thanks, Fred.
StephenW
(To:FD_9999148)
When you say "no luck", what do you mean? Is the failure in your sketch or the creation of the plane?
What I mean is when I extrude from the horizontal plane that is created, is there a way to follow the angle on the outside?
StephenW
(To:FD_9999148)
Took me a while to find the serration. I think you will want to make the serration as a sweep feature so the one feature goes top to bottom.
I sketched a curve using a silhouette of the cap.
Then created a sweep cut using the curve to define the trajectory.
Then I patterned using axis pattern 106 times around.
Not sure this is what you are after but...
Stephen, this is exactly what I needed to do thanks, Fred. Have a good day.
StephenW
(To:FD_9999148)
