When I try to change a dimension of revolve diameter on "Cut id 174" from 1.22 to 1.23, Pro E show "some features failed to regenerate"
Need help to figure out the reason and fix it, thanks!
Bill
It's likely an accuracy issue. Go to file - prepare - model properties - accuracy - change and adjust the accuracy to a smaller number.
Stephen, you are right!
I changed accuracy from 0.002 to 0.0002, and the error gone. Thanks...
