can anyone give insight on how to have creo automatically output feeds and speeds based on material.
See the attached. The document is old but the technique is the same.
Creo will build .xml files for each tool containing the feed and speed information. Then when you create the manufacturing model you can define the material. Your site file will often contain relations to automatically read the tool feeds and speeds.
Dear Sir,
Can you please help me on the Post processor for HAAS VF4 4th axis?
CAM: Creo6
