feet inches fractions
davehaigh
I'm sure this has been asked before. How do I display dimensions on a drawing in feet, inches, & fractions?
If I have to modify the part units, ok, but I'd prefer not to.
Actually both solutions would be good.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
7 REPLIES 7
I asked this not too long ago and I am pretty sure I did a summary.
You'd have to look it up. If not I may have it somewhere.
BenLoosli
(To:davehaigh)
May 7, 2012 4:25PM, Wayne summarized with:
Only one response to this. Thanks Bill Chapman.
Set these options in the config.pro to get dimensions in feet and
inches:
! Use these to dimension in feet inches (5' 3")
USE_MAJOR_UNITS YES
CREATE_FRACTION_DIM YES
DIM_FRACTION_DENOMINATOR 16
Thank you,
Ben H. Loosli
USEC, INC.
Thanks Ben! I feel like I have something more. Will have to look.
davehaigh
(To:davehaigh)
I think the answers given need some clarification. You need settings in both the config.pro and the detail setup file.
Detail Setup options
davehaigh
(To:davehaigh)
One correction.
The Drawing_units = foot detail setup option is not one you want. It makes the text height, dimension arrows, etc. measured in feet.
David Haigh
davehaigh
(To:davehaigh)
One last thing, typically when you are showing feet, inches, and fractions, you don't want to show tolerances.
So you should add this to the config.pro
Tol_mode nominal
I'm going to create a new .dtl file and a config file with the options it needs and then create a mapkey to load them when I need them.
David Haigh
David,
Its all good! Thanks. I am saving this in my tips folder.
Wayne
