file size wf3 vs creo2
Inoram
Why is a part model that is about 5meg in WF3 close to 200meg in Creo2?
TomD.inPDX
(To:Inoram)
Your graphics accuracy settings affects the file size. The files have embedded the shaded graphics and LOD data and with high setting in your config, it will safe a lot of facet data. You can get around this by changing the config.pro option: save_model_display wireframe
You can also reduce your graphics quality options before saving but I find the setting above to be more consistent.
Inoram
(To:Inoram)
Sorry meant to say imported geometry file size.
Dale_Rosema
(To:Inoram)
Could it be that default accuracies are different? Not sure - just a guess.
TomD.inPDX
(To:Inoram)
Inoram
(To:TomD.inPDX)
yup, that did it.. you're the man.
173 meg now 3 meg file. As long as it doesn't lose any actually model data, which I don't see why it would.
TomD.inPDX
(To:Inoram)
No loss of data. I suspect it is built-in JT data for some of the advanced modeling extensions for faster loads. I only learned about this when I was making glamour shots (screen-caps) with high graphics quality setting and not resetting it back to normal. File size went through the roof! With the config.pro setting as wireframe, I didn't have to worry about where I left the graphics settings during any of my saves.
