I am using Creo 8.0.4.0 software, As I am creating the sketch and adding the points to find the coordinates values and adding the values in parameter, is there any other way to find out the coordinate's values of the boundary box without adding the sketch and creating points and add. I want to find out the coordinates values without creating the points. if anyone known the answer please reply.
Thanks & Regards
I take it you are looking for the model bounds dimensions. If you have access to the mold base extension (EMX) you can get it directly from within Creo Parametric.
Refer to this thread:
How to get overall size X, Y, and Z coordinates of... - PTC Community
Modelcheck and some of the Creo Parametric APIs can extract the parameters of interest.
