fix_param.log
DavidReich
fix_param.log
Does anyone know what can cause Pro-E to create a fix_param.log file?
the contents of the file are rather unhelpful in diagnosing the problem...
Deleted parameters in model AS4330K04-035_MS:
Deleted parameters in model AS4327K04_MS:
Deleted parameters in model AS4326K04_MS:
Deleted parameters in model :
I haven't been able to find anything special in the files that would make them different and none of the paramaters actually get deleted since I can open the file (which generates the std.out and fix_param.log), regen, save, then reopen and it does it again. I started investigating these files because pro-e always considers these files modified and in need of regeneration.
I am using WF 3 M200
Thanks for your help,
Dave
Darrell
(To:DavidReich)
It looks like it's supposed to be a log of duplicate parameters removed from models. There is an SPR that says they made a change in WF3 M220 to correct a problem with the file being created even when no duplicates were removed.
