Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Time to create a "Quick Print" of my assembly with 4 views: 15 minutes.
Time to create a drawing of my assembly & add 4 views: 2 minutes.
Huh?
Lyle Beidler MGS Inc 178 Muddy Creek Church Rd Denver PA 17517 717-336-7528 Fax 717-336-0514 <">mailto:-> - <">http://www.mgsincorporated.com> This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
