hide bom table on drawing, keep balloons
jme
I have a BOM and balloon callouts on a drawing.  I need to hide BOM table but keep the balloons because we use a separate PDM system to create BOM's.  So how can I do this?
3 REPLIES 3
Chris3
(To:jme)
StephenW
(To:jme)
Another possibility is to simply move it well outside of the format. This may not be acceptable if you are using Creo view or other viewer programs but if you are creating PDF or other paper type outputs, you can just printa full plot and doesn't grab the external stuff outside the format.
I would also advise to place the table on a Layer and hide the Layer.
Amit
