how to create hole patterns using dimensions with relations increment,
thanks
Hello Prashant and welcome to the forum.
Can you explain better what you mean by increment?
I am pretty sure the answer is yes, but maybe not as simple as just having an equation to manage the increment.
For instance... if I want a location series of 1,2,4,8,16 unit spacing, I might have to use a pattern based on points. The points will be defined using relations to locate the point in relation to each other.
* -d1=1- * d2=d1*2- * -d3=d2*2- * -d4=d3*2- * (etc...)
below is the image for your query related to increment for hole patterns,
Message was edited by: Prashant Shinde
