holes table/chart in drawing
Trebla
Is there a way to highlight the note, when I select a reference from 'holes table' in drawing?
For instance, I would like that If I pick 'E2' in the table, I could see the note from E2 highlighted. I think this could be useful in big tables.. I am using creo4.
Thank you
1 REPLY 1
BenLoosli
(To:Trebla)
Also show the 0-0 reference location for the origin of the locations on the hole table when highlighting the hole being queried.
I haven't used hole tables in a long time, but I would think the hole diameter would also be important, unless that is done in a separate table for the A to K hole diameters.
