We are aware of an issue causing intermittent login problems for some users following a recent update. Learn More
how can I move a datum tag which belongs to a datum that is part of copy geom. feature. all the datum tags which are copied into the publish geom feature are aligned .
Hi Simon,
Can you send an image of what you are seeing? It might help to better understand the issue.
Amit
