how can i name a face
ufrigge
How can i name a face or a set of faces?
TomU
(To:ufrigge)
The way I've always seen this done is from model properties.  File --> Prepare --> Model Properties --> Names (Change).  Just pick a face (surface) and name it.
This works for any of these types:
5 REPLIES 5
Mahesh_Sharma
22-Sapphire I
(To:ufrigge)
Uwe,
Could you please explain this in detail?
ufrigge
(To:Mahesh_Sharma)
i want select one or more Faces and then givem them a name. Named faces can very easy found by the search tool.
sully7
(To:ufrigge)
Uwe,
I've found personally that the easiest way to name a surface is to use the "Parameters" window.
With your model open, go to Tools -> Parameters. In the window that appears, change the dropdown to select "Surface"
You can then enter the desired name - here I use "SIDE_OF_BOX" as the name.
Once that is complete, your surface will have the assigned name.
You can check this using the "Find" tool (CTRL+F) - and searching for "Surfaces" - "By Name". You should see your new name in the list of results.
There may be a much faster way to do it... but that's just what I've always done
Hope this helps!
James Sullivan
CadActive Technologies
President & Founder
President & Founder
CadActive Technologies - www.cadactive.com
ufrigge
(To:sully7)
Hello James,
thanks for your detailed answer.
TomU
(To:ufrigge)
