I must route several cable with pro/cabling, but i would like a placement of cable different than flat or round (two bunk flat of 4 wire, then 8 cable).
Have you a idea to change the cross section of a bundle of cable?
Thank for your quik reply.
But i still can not route as i want. I try route two flat bundle separetly ( one tanjent to the surface, the other offset of the diaméter of wire).
I have join a picturethat show my new problem . And, imust routewire in complex assembly (on the picture is juste a test),So I think it will be very difficult with this method.
If you have any other idea, I'd be very grateful!
