how to add parameter in all subsequent family table ?
pzala
7-Bedrock
I am desining one model, with multiple feature options. in Family table I have defined two instances 1 and 2. Now, the 2nd instance also has family table of it's own and instance 3 inside it.. One parameter in main model, which is "Yes or No" type, need to be "Yes" in instance 1,     "No" in instance 2 and "Yes" in instance 3( which is member of 2nd instances family table).
But creo 2.0 is not allowing this. If I add this parameter in family table of main model, then I can't add it in family table of instance 2. If I add it in family table of instance 2, I can't in main model? Is there any option.
MartinHanak
(To:pzala)
simply create instance 3 in 1st level family table. You do have to create 2nd level family table.
Martin Hanák
