how to add weight column in BOM
kb-3
2-Explorer
procedure
MartinHanak
(To:kb-3)
please provide more details. For example:
Do you use Bill of Material command in Assembly mode ?
-OR-
Do you use Repeat region table in Drawing mode ?
Martin Hanak
Martin Hanák
kb-3
2-Explorer
(To:MartinHanak)
is there any bill of material option in creo
i used repeat region
i need to create a weight parameter in part and i have to call back by asm-mbr-parameter-weight
if any easiest matter apart from these tell me and thanks for your reply
MartinHanak
(To:kb-3)
look into Re: how to develop a relation for calculating the mass of part in BOM discussion - PRO_MP_MASS system parameter.
Martin Hanak
Martin Hanák
