how to change text size or font in the edit pop-up window not the drawing?
wsourbeer
I would like to make the text in the editor window bigger for easier reading as I'm typing. Can this be done?
5 REPLIES 5
Hi William,
Config.pro option "fonts_size" might be what you are looking for.
William,
please attach a picture screenshot of text editor window.
Martin Hanak
Martin Hanák
In the two views below what I want to do is to have larger text in the edit windows without affecting the drawing text (in green on drawing). Can this be done and how.
in the image above choose tab text style, and there you even can make a preview i think
William,
if I understand you well, you want to enlarge text in red frames (i.e. @O, option names, button names).
I guess, that the only possible way is to play with Windows settings for various window elements. But it is also possible that these settings are hardcoded in Creo and user cannot change them. I have never tested such functionality...
Martin Hanak
Martin Hanák
