how to convert iges file in to part file creo?
aminhas
Hello everyone,
any buddy guide me how to make drawing attached file part in Creo 3?
kind regards,
Adnan
Hi Adnan,
Open the iges file in Creo and save as a new file. *NOTE, when opening, you will need to change the TYPE to All in the open box to see the required file. Then create a drawing, if you use the same file name, it will pull the part into the drawing automatically. Add views to the drawing as you would anything.
Hope that helps.
