how to do sum quantity seperately for eachpartnumber
dkumar-10-11-12
Greetings everyone!!
I know how to sum the whole table qty. But all I need to know is how to sum  up the qty for each part number in the table.
As in the pic,  I need to calculate the sum for “BK-16-GXL”   in the qty coloumn .I've attached a snap for ur reference...KIndly help me
do i need to use any relation or modify repeat region options ? Let me know
7 REPLIES 7
Go to TABLE - REPEAT REGION - ATTRIBUTES - NO DUP/LEVEL
thank u for ur reply stephens... @stephens williams
in repeat region there is a option to add the total quantity by "SUMMATION"
In that we can add the total quantity and get the answer in single cell.
but i want to add seperately for each color
for example
i want to sum up "BK-16-GXL"  qty as 83.95+152.312+185.403 in a seperate cell...
If summation works then maybe you should just do multiple repeat regions for each part with a filter.
thank u christopher...
but if u never mind...could u please explain elaborately... i cant understand plzzz
how can i do repeat regions for a seperate parts???
is there any options for it??
Table Tab -> Repeat Region -> Filters -> Pick your Repeat Region -> By Rule -> Edit
Then paste something similar to what you see below:
&asm.mbr.name  == BK-16-GXL
Then Close -> Save-> Done->Done
Then copy and paste the repeat region only change the filter to be a different part number for the new copied repeat region.
Repeat as needed.
