how to get dimension values
ss-10-11-12
     anybody please help me to get dimension name and its values for a given creo part using jlink coding.
send any idea about that dimension name and values.
3 REPLIES 3
I don't use jlink but here is an excerpt from the user manual -
Dimension Objects
Dimension objects include standard PTC Creo Parametric dimensions as well as reference dimensions. Dimension objects enable you to access dimension tolerances and enable you to set the value for the dimension. Reference dimensions allow neither of these actions.
Getting Dimensions
Dimensions and reference dimensions are PTC Creo Parametric model items. See the section Getting ModelItem Objects on page 208 for methods that can return Dimension and RefDimension objects.
Dimension Information
Methods Introduced:
• pfcModelItem.BaseParameter.GetValue
• pfcModelItem.BaseParameter.SetValue
• pfcModelItem.BaseDimension.GetDimValue
• pfcModelItem.BaseDimension.SetDimValue
• pfcModelItem.BaseParameter.GetIsDesignated
• pfcModelItem.BaseParameter.SetIsDesignated
• pfcModelItem.BaseParameter.GetIsModified
• pfcModelItem.BaseParameter.ResetFromBackup
• pfcModelItem.BaseParameter.GetIsRelationDriven
• pfcDimension.BaseDimension.GetDimType
• pfcDimension.BaseDimension.GetSymbol
• pfcDimension.BaseDimension.GetTexts
• pfcDimension.BaseDimension.SetTexts
All the BaseParameter methods are accessible to Dimensions as well as Parameters. See the section Parameter Objects on page 257 for brief descriptions.
Note
You cannot set the value or designation status of reference dimension objects.
Apologies for copy/paste formatting
thank you ..so much
Yes, I saw those in the manual to.  It is useless without example code which the manual does not provide.  Does anybody know where to find example code for extracting dimensions from a drawing?
