i just created a pipe drawing in creo2.0 and i want to make the drawing without centre line of it.
The way I hide the centerline is I add the pipe feature(s) to a layer and then turn off that layer in the drawing. Creo won't hide the solid geometry when you add the feature to a layer but it will hide the centerline. Don't forget to save layer status in your drawing once you hide the layer.
thank you verymuch stephen
Hi Steven,
What you have said it's true and works fine.
But I'm not able to create a rule to collect all pipe feature of the assembly.
Do you know how to do? I can't find the right settings into the searching tool.
PS: I use WF5.
