how to hide the center line of a pipe in a drawing?
viswarya
2-Explorer
i just created a pipe drawing in creo2.0 and i want to make the drawing without centre line of it.
StephenW
(To:viswarya)
The way I hide the centerline is I add the pipe feature(s) to a layer and then turn off that layer in the drawing. Creo won't hide the solid geometry when you add the feature to a layer but it will hide the centerline. Don't forget to save layer status in your drawing once you hide the layer.
4 REPLIES 4
StephenW
(To:viswarya)
viswarya
2-Explorer
(To:StephenW)
thank you verymuch stephen
Hi Steven,
What you have said it's true and works fine.
But I'm not able to create a rule to collect all pipe feature of the assembly.
Do you know how to do? I can't find the right settings into the searching tool.
PS: I use WF5.
sully7
(To:viswarya)
This too: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS44077
President & Founder
CadActive Technologies - www.cadactive.com
