how to identify origin of a drawing?
Most drawings in Creo have the origin in the lower left corner.
Are you trying to do it with toolkit or something else?
You should specify what version of Creo you are using along with a better question that explains what you need.
@Ketan_Lalcheta I think there is no option or choice available for users to define the origin for drawing. If you will create a line in drawing, use Absolute coordinates 0, 0 you will get location for line.
You might check the draft grid origin. You can specify different locations for it. For example, you could set the top-right corner of the drawing to be 0,0. I'm not sure how the draft origin interacts with the drawing template. But I do know template views can be moved using absolute coordinates defined by the draft grid origin.
