Dear all,
I am newbie in PTC Creo parametric 3. I want to draw a ribbed-pipe (i send you sample of ribbed tube). I am trying to make the ribbed on the wall by using sphere and cylinder. But, When i try to remove material (by using extrude option) of the main pipe I get some trouble such as material cannot be removed. Do you have any suggestion?
Thank you best regards
Teguh
I might try this as a surface model; merged and thickened.
I managed to do it like the attached.
Basically, I created two set of the ribs first (the ones that would sit tangent to the axis line on your JPEG):
Then create the pipe using whatever way you like. I chose to extrude from a start point, where the inside surface was tangent to the planes created earlier
