how to show automatically number of holes in creo drawing
VB_11781241
In any drawing which contains holes normally (written manually (2x) M12)   How can i make the number of holes should be automatically generated ?
Dale_Rosema
(To:VB_11781241)
Are these holes part of a pattern?
It is still manual, but you can add &p# (where # is the number of the pattern) and it will automatically update the number of holes if they change.
7 REPLIES 7
Hi @VB_11781241,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. You could add the below data -
  1. Software Version: Which version of Creo are you using?
  2. Desired Outcome: What exactly do they want to achieve?
  3. Steps Taken: Have they tried any methods or settings within the software to achieve this? If so, what were the results?
It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
I am trying this in Creo 8.0,
currently i am writing it manually, i am looking for the default option, it can calculate the number of holes automatically
Dale_Rosema
(To:VB_11781241)
Could you give more information, where to write this &p# should be written
Dale_Rosema
(To:VB_11781241)
Thanks for the reply,
I have tried looking at the link you given,
didn't give me any result, its not reading as a function, it just show what i have written, i have tried with brackets, spaces & few combinations,
Also how to look for (where # is the number of the pattern), does pattern will have its ID number ?
Dale_Rosema
(To:VB_11781241)
Editing the dimension @D for the diameter of the hole, the &p8 X was added which shows the 10 X in red.
The "8" came from the dimension in the pattern of the holes.
