i would like to understand the template names when starting a new document
PG_11980159
3-Newcomer
i would like to understand the template names when starting a new document. is there a reference to all the template names (eg mmks_asm.design_abs and all the other variants)
They are abbreviated
in = inches
mm = millimeters
k = kilogram
abs = absolute accuracy
rel = relative accuracy
n = newtons
s = seconds
and so on.
4 REPLIES 4
Here is some information about template names ( Predefined Systems of Units).
There are two Unit Systems:
Mass length time (MLT)
Force length time (FLT)
MLT ( Custom System of Units). If you choose the MLT unit system, then the name will be LengthMassTime. If you choose the FLT unit system, then the name will be LengthForseTime
Here are some useful information about Units in general ( About Units)
There is also the part/assembly type
Finally, absolute tolerance vs relative tolerance (Absolute and Relative Tolerance Settings)
So the template name is as follows
MLT unit system: LengthMassTime_part/Ams Type_abs or rel.
Force length time (FLT): LengthForceTime_part/Ams Type_abs or rel
Regards
Bassam
The Help Center provides access to documentation for your application and to other resources such as free tutorials, release enhancements, and toolkit guides.
support.ptc.com
BASSAM YAZIGI
CREO Product Lead
Find a training session today!
ptc.com
upload_-T3V0bG9vay1jaWRpbWFnZTAwLnBuZw==-4173992196372182796..pngupload_-T3V0bG9vay1zaWduYXR1cmVfLnBuZw==-993121193556286216..png
template names.jpgok, i was more so looking for these explanations, mmks, mmns, list goes on
in = inches
mm = millimeters
k = kilogram
n = newtons
s = seconds
and so on.
thanks Michael, it seems so obvious now that you have said it, 😀. cheers for the info
